Connect 2 faces to create a solid object
mjørgensen
Hi community people,
I am VERY unfamiliar with 3D drawing tools, so please bear with me...
I am trying to create an object, which "almost" is a 2-D drawing, which must be pulled 30mm.
But the Top/Bottom surfaces are a little bit different.
I have tried to define 2 surfaces "Top"/"Bottom", but I do not know how to combine these and add the missing surfaces.
I have tried to use "Gather Faces" without success
Am I doing it totally wrong?
Best regards
Martin
PS: I am using "CREO Elements Direct".
I actually figured it out myself (after watching 50+ videos).
I created a parallel copy of the workspace, and used Loft...
How did you do that with the date?
Great, congratulation
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Hello Martin,
can propose 2 ways.
Move Bottom 30mm away from Top.
Proposal 1
Make w1 nonvisible and follow the description in the picture for every pair of conture elements.
At the end if everything is closed you can gather Top with "Gather Faces" to Bottom.
If you dit all wel the surface part will become a solid part.
But this all is a lot of work.
Proposal 2
Pic-1 create new workplanes on Top and Bottom and project real geometry.
Pic-2 create a workplaneset S1 and move the workplanes what you have just created into it.
Make Top and Bottom invisible = uncheck in Structure Browser..
Now create a Match Line. You need only one but dont foget to terminate correctly.
Now you can create a loft. See picture.
Good look and best regards
Friedhelm
