Hi
Is it possible to import a phot or 2D drawing and have on one workplane and on another copy over the photo or drawing ? Is there a good tutorial somewhere, have done some searching with no luck.
Thks
Charlie
Hi Everyone
Can someone help me out with this question. I am sure it is a simple procedure, but I have not been able to locate an answer.
our help would be appreciated.
Regards
Charlie
original poster
Hi charlie,
may be an idea...
I am actually using Cocreate Modeling 17.0 software. To insert a photo or drawing I use the rendering module.
I copy a material and change its texture in the parameters by browing a .pjg file ( or else...).
Just have to scale it afterward.
regards
denis
browsing and not browing!!!!![]()
you can use the Rendering Module and add a Decal to your part. Add Decal in the rendering module.
this would enable you to add this to your part. (rotation and placements on face is possible)
Hi
Thanks for the info.
Can you give me a url where the down load for rendering is, for Creo 4
I have searched with no luck.
Charlie
hello,
its part of the professional version of Creo Elements/Direct Modeling. Go to the View Tab or activate it thru Modules..
If you use the Creo Elements/Direct Modeling Express - also known as "Modeling PE" then the Rendering module is not available. See the comapre sheet on the Modeling Express sheet to see the differences.
http://www.ptc.com/WCMS/files/129462/en/6772_Creo_Express_TS_EN.pdf
