Making Hexagons
simdude_17
Making Hexagons
How do I create a hexagon on an offset workplane that can be lofted from a cylinder? I am using Pro Desktop, why has PTC got rid of all help files for this?
You mean a blend between 2 different geometries. In order to do this both geometries must have same number of vertex (hexagon has 6, cilinder has none), therefore you need to divide the cilinder proyection (circle) in 6 parts, use centerlines from the center, at specifi angles, and then use the divide tool, I beleive is in the same trim icon menu. Then you can do the blend
