Old Macros
mzayas
Old Macros
Is there a way to transfer over old macros from OneSpace Drafting 2007 to Creo Elements/ Direct 18.1?
mbonka
(To:mzayas)
l´m almost sure, that it is not possible. OneSpace Drafting 2007 is absolutly different program... or the way to trasfer will be so complicated, that much more easier is create your macros again directly in Creo.
FriedhelmK
(To:mzayas)
Hi Marje,
Do you meen to Creo Elements/ Direct Modeling 18.1
or
to Creo Elements/ Direct Drafing 18.1
In the 1.case I follow the opinion of Milan
In the 2nd case, I think that you can take everything over except very few exceptions.
You have to test everything, of course,
especially if eventual errors can cost a lot of money.
Best regards
Edit: Ps.
If you stay in the same user interface.
If you want to change for example to the Ribbon that means quite a lot of effort.
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
