Sequence visibility in Creo 2.0
razmosis
Just starting with Creo 2.0 and when I open an existing Manufacturing file, the model tree only shows the Operations. The individual Sequences that make up the Operation do not appear, as they did in Creo Elements / Pro 5.0. I am sure that this is something that is very simple to get, but I just can't find the right thing to select to make it happen right now. Any help is definitely appreciated.
Hi Matt
You don't have the manufacturing module loaded. That is why you don't have any sequences.
Creo has a new .EXE file that replaces the the old ptcstup.bat, you need to run it and reconfigure your setup, it is reconfigure.exe.
it is in the folder C:\PTC\Creo 2.0\Parametric\bin
you need to get to this screen, then press the customise... button
then select the tab highlighted then select EDIT
you can then select the arrow for the floating module, this will expand to show what modules your license supports, then use the arrow highlighted to install.
this should get you out of trouble.
Peter
