Since Creo Drawings don't have a "Spell Check" function, I read somewhere that you can set one up in Model Check. Does anyone know if this is true? If so, does anyone know how?
ModelCheck does have a spell check function.
I have set it up to work here. There are a lot of words we use that have had to be added to the dictionary file.
Read up on ModelCheck in the documentation.
I have moved the ModelCheck files to a network shared location outside of the Creo default location. This eliminates Creo builds overwritting my files until I can incorporate them into what we want ModelCheck to check.
I also use it to check for designated parameters in Windchill for value and designation. In some cases, these will trgger an error and prevent the file from being checked-in to Windchill until the engineer fixes the issue.
