Hi Experts,
In Drawing sheet i need to find the Grid location where the notes is placed. Using Vb api, Toolkit Code Or Macro. Help me to find it out.
Thanks in Advances.
Sujithkumar.N
Please specify the version of the program you are using.
Creo Version 8.0 Program language C# and VB
You are in the wrong forum.
PTC has two CAD systems: Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
