what is the "percentage" shown in the lower right corner of the Model Manager window?
PeterKehoe
lfortner
(To:PeterKehoe)
I assume it's a ratio between used memory and max memory as:
(total - free)/max
where:
- total: the total amount of memory in the Java virtual machine
- free: the amount of free memory in the Java Virtual Machine
- max: the maximum amount of memory that the Java virtual machine will attempt to use
When you press the mouse in this panel, it's supposed to run the garbage collector, a process where the Java Virtual Machine expends best efforts toward recycling unused objects in order to make the memory they currently occupy available for quick reuse.
lfortner
(To:PeterKehoe)
(total - free)/max
where:
MaxR.Kublin
(To:lfortner)
Hi Louis and Pete,
The interesting part is how you get this panel.
I don't have it in my MM V19 😞
Cheers,
     Max
lfortner
(To:MaxR.Kublin)
Hey Max,
There are several conditions that make this panel appear. Let have a look at ManagerPanel.java, init().
The most current is when you debug the application from NetBeans..
Alternatively when your environment variable DEBUG_MM is "true".
Hope this helps you.
MaxR.Kublin
(To:lfortner)
Louis and Pete,
The value (percentage) and behaviour is exacly Louis described.
Since MM ships with Java-Sources, you can look it up in
com\osm\ui\MemoryPanel.Java
The code also does a call to gc() which is the garbage collector when you click into the Window.
@Pete: You must be running DEBUG_MM=true - correct?
(from the sources, I clearly conclude that this Panel is only shown when debug is true)
      Max
