I have used the precursor version of this software at my work place.At that time, it was known as SolidDesigner which used a tablet interface. I am still getting familiar with the latest OneSpace Modeling PE and its ""window""like interface. It takes me a while to navigate the menu to search for the commands I used to use. I notice that when I create a new workplane (parallel to the face of a cube for example) , the new and active workplane does not automatically position itself parallel to the active viewport what I mean is that the W vector is perpendicular to the viewport. Thisfeature is automatic with Solidesigner). I have to use the workplane positioning command to get what I want. Is it normal with Modeling PE ? is there a way to make it happen automatically when I create a workplane? Appreciate any help
anonymous wrote:
Yman - 2007-05-30 10:56 PM I have used the precursor version of this software at my work place.At that time, it was known as SolidDesigner which used a tablet interface. I am still getting familiar with the latest OneSpace Modeling PE and its ""window""like interface. It takes me a while to navigate the menu to search for the commands I used to use. I notice that when I create a new workplane (parallel to the face of a cube for example) , the new and active workplane does not automatically position itself parallel to the active viewport what I mean is that the W vector is perpendicular to the viewport. Thisfeature is automatic with Solidesigner). I have to use the workplane positioning command to get what I want. Is it normal with Modeling PE ? is there a way to make it happen automatically when I create a workplane? Appreciate any help
