Transparent colors within Technology colors?
eknudsen
1-Newbie
Hi everybody,
Anybody knows how to add transparent colors to the technology colors?
Best regards Clement
2 REPLIES 2
tschneyer
6-Contributor
(To:eknudsen)
Hello Clement,
What version are you working with?
This functionality is available in the latest releases EMX9 M012 and in EMX8 M026 or higher.
Simply edit the file color_definition.cfg in the configuration folder.
You can add a 4th coloum for each technology color between 0 and 1 to set up the transparency.
Regards Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
Hello Thomas,
Thank you for your answer.
We´re using EMX9 M010...
I just updated tha color definition file per your suggestion and it does not work.
I guess we need an update of the EMX then. Could you provide us with an update? M012...
Kind regards
Clement
