Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
I think you would be better served using a decal for what you are doing. Decals can be saved with the part.
How to apply an image or decal to a Creo Parametric model as a texture - EAC Tip of the Week (youtube.com)
The method you are using to add t...
View more
Hi @rleir
The import is just example of my own class and how to call the method from JSP page.
You can use any classes what you need from the Windchill.
My class contains my own methods that do something.
If you call the ODATA from JSP you alway...
View more
Hello EveryoneGood Evening, I am facing problem in logging properties there are some values which are repeating after I carry out the experience multiple times.PFA attached image in which arrows are shown on the readings which are repeating when I co...
View more
1. How can I search for each frequency range?For example I looked into the excel file and I saw that 1kHz begin from line 61536 and is ended at line 62560:
Therefore I extracted manually the respective range in Mathcad:
So, for...
View more
Check out this video on Creo "Sketcher" from PTC Application EngineersPresenters: Emily Pinto (Solution Consultant) and Ryan Butcher (Solution Consultant, Fellow)Original Date Presented: March 19, 2024 To dive deeper into the subject, check out Creo ...
View more
