About publish geometry
Highlighted
Newbie
I have one basic query.
In top down design approach, I have created one assembly, sub assemblies,
parts in sub assemblies, and a top level skeleton. In skeleton, I have
created two surface features separately. One of these are published, and
copied in down level parts. Now, some solid feature is created using
reference of this copied geometry.
If I replace the surface in publish geometry with other surface, my down
level components are failing. I have to give manually reference to the new
geometry. My intention is to change the published geometry and my down level
assembly should get regenerated without failing. Kindly help.
Thanks in advance.
Best Regards,
Girish Kulkarni
