You can only modify that RMB using Smartmenu from the folks at B&W software. Outside of that you would need to know how to modify Pro-E using Pro/Toolkit and other knowledge to make your own. I have used the SmartMenu and it works plus you can add just about any menu command to the RMB.
Eric
We are using the SmartMenu Application form B&Wsoftware. That allows adding RMB menu buttons and submenus. It also provides the ability to add or remove menu entries from the main menu bar without touching the config.win file.
It works fine for us 🙂
Jan
In Reply to Yugendra Bhide:
Gurus,
Is there a way add commands like ordinate dim, repeate etc to menu that
appears when right mouse button is pressed. We are trying to give quick
access to these frequently used commands without having to type mapkeys.
Thanks!
Yugendra
Yugendra Bhide
Design Engineer
Norse Dairy Systems
Columbus, Oh
Ph (614)-421 5305
Fax (614)-421 5438
http://www.norse.com/
This email and any files transmitted with it are confidential and intended solely for the person(s) or entity to whom they are addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error, please contact the sender and delete the material from any computer.
I have attached a flyer to this post that is from B&W software. It includes pricing, in euros, and contact information.
Sincerely
Eric
