All,
First off, I am using Creo 2.0 M090 if it makes any difference. Anyway, I have someone looking to find the area of the section of where a tube wall meets a cone surface going through it. Attached is a picture of the parts in question but I have not had to try and measure an area that is a radius tube intersecting a radius cone. Can't really do an exact cross section because of the two rounded surfaces. Although, even a cross section through two vertex's tangent to the tube wall may be close enough. So a solution to either of those cases would help out.
Thanks in advance,
Shane V.
