Blend from file
Ketan_Lalcheta
Blend from file
I have couple of questions on this:
1. Is this trust worthy command?
2. As this is not present in ribbon, how can I use it?
3. This command is a option to create surface. Another option is to create points, curves and then boundary blend. Which approach will give better surface quality and why?
Any thought on this?
Regards
Ket
0 REPLIES 0
