Boundary Blend Creo 2 vs Creo 3
CoreySusie
Running Creo 3.0 M070 and Creo 2.0 M110.
Creo 3.0 has a "Create as Solid" and "Create as Surface" option as well as a flip arrow.  I haven't found this documented anywhere.  It doesn't appear to make a difference between the 2 options, they both produce surfaces.  Any idea why its there?  I presume it could possibly consolidate BB with Solidify when applicable, but doesn't appear to work yet... See screenshots below.
Creo 3.0
Creo 2.0
1 ACCEPTED SOLUTION
CoreySusie
(To:CoreySusie)
The menu picks shouldn't be there in regular mode of Creo Parametric.  The issue has been resolved in Creo 4.0 and is working to be resolved in Creo 3.
https://support.ptc.com/appserver/cs/view/spr.jsp?n=4876657&source=Case%20Viewer
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS221190&source=Case%20Viewer
7 REPLIES 7
The boundary blend needs to create a watertight surface or watertight patch on an existing solid.
CoreySusie
(To:danderson)
I tried that with the solid option, still produces a surface patch only.  You have an example of it producing a solid directly out of the BB tool?
CoreySusie
(To:CoreySusie)
I also find it interesting why they didn't speak of this in the Whats New in Creo 3.0 documentation but they talk about the Optimize button?
Sorry, but i don't fully understand your example...could you post it?
Solid boundary blend is for sheetmetal module
but the boundary blend for sheetmetal is already there in Creo 2.0.
Either its a bug..or someone need to dig in deep
CoreySusie
(To:CoreySusie)
