Boundary Edit missing in Import Data Doctor
Highlighted
Does anyone know how to delete a boundary from a surface that has been split into multiple pieces using Import Data Doctor? In WF3 and prior we could use Edit Boundary>Delete Contour and select the contour that needed to be removed. In import data doctor, I can select an edge and click delete, but that removes all boundaries of the surface, not just the one I want removed. The image below shows an example of the issue, I would like to delete the sliver surface in the corner (circled in red, part of the larger surface) without losing the rest of the boundary.
Josh
