Copy Surface Finish Symbol
Is there a way to copy a surface finish symbol in a Creo Elements/Pro 5.0 drawing? I'm pretty sure I used to be able to use copy/paste in Wildfire 4.0.
Keith
Tags (1)
Re: Copy Surface Finish Symbol
Hi
As per my knowledge you can also do it in wf-5
Go to Annotate (Ribbon) and try to copy the surface finsh symbol
K.Mahanta
Thanks for the reply. Unfortunately, the copy command is grayed out when I select a surface finish symbol, even with the Annotate ribbon active. Am I missing something obvious?
Thanks again,
Keith
I just spoke to PTC support. Apparently, I was never able to do this. Oh well. Sorry for the confusion.
Hi
If you have created it in the model thru annonation ; then you can not copy in in drawing
But if you have created it in drawing thru custom symbol; then you can copy in drawing
K.Mahanta
