Creo Parametric appearances: custom libraries of common surface finishes?
Highlighted
Participant
From what I gather, Creo Parametric has a very basic material library, which is missing many very common surface finishes.
I've heard that, in order to procure magical dmt files that contain clear brushed aluminum, yellow and white zinc, tin, chromate, black oxide, brushed stainless steel, and other assorted apparently-exotic finishes, you need to cozy up to some wizened Pro/E veteran and convince them to share their personal dmt files with you.
Is there anyone resident on this forum that would like to share their dmt libraries?
Thanks in advance,
Mike
