Creo4 performance/hardware choices?
Participant
We are looking to move to creo4 how are people finding the performance?
I am looking at upgrading hardware here for the team and want to make the right choice, if anyone can comment its appreciated.
I have a user here with a dell 5510, 16GB ram, Nvidia M100M who has been using creo4 F000.
There seems to be some hang/delay when redefining part features we don't normally experience this in creo3, does anyone else notice this it is quite annoying in workflow?
I know creo 4 is on F000, when the first maintenance release happens the intention is to move the team to creo4.
We have a few users on dell m3600 16GB nvidia k1100m running creo3 its mainly concept/industrial design type work though we do frequently deal with large complex parts and assembly(we have parts up to and occasionally over 500mb). Opening/manipulating assemblies or even part files can be slow/painful. FYI also use keyshot/rhino/modo etc
Upgrading i was looking at dell5520 or 7520, next gen 2/4gb gfx and at least 32MB ram, i am hoping the memory increase will help improve overall performance, we have to be fairly mobile so workstation isn't really an option and we aren't bodybuilders to be carrying around a 7720.
Obviously laptops are immediately limited on heat/power compared to a workstation, i would like to hear others opinion on hardware choices and creo.
Thanks and regards! Daniel
5 REPLIES 5
Re: Creo4 performance/hardware choices?
I don't have experience of Creo 4 specifically, but in general Creo needs good single-thread CPU performance.
This is one benchmark site that I use, and from a few tests seems to correlate quite well with regeneration speed in Creo (other benchmarks exist and may give different results, though this one has the advantage of listing most CPUs):
PassMark CPU Benchmarks - Single Thread Performance
Basically, you want a CPU as high up this list as possible.
Personally I've found the video card to be less critical in general modelling than the CPU; and memory is very much down to the size of model / assembly that you're working with - the best thing there is to watch the memory usage of xtop.exe in Task Manager with a typical large model open (remembering that you want to leave Windows a decent amount spare for overhead, caching and other applications).
which hardware have you ordered?
Are there any performance differences regarding L3/L2 Cache size? Xeon has higher Caches, i7 faster cores. Is i7 still better?
Spec has Creo 3.0 benchmarks, but the data is very little. Vendors like to sell their Xeons ^^
http://www.spec.org/gwpg/apc.data/specapc_creo30_summary.html
anybody has tried PCIe SSD or different RAM Types?
yes, GPU is less important except for rendered vs wireframe drawings.
br Bernhard
Hello all,
I am using CREO 4.0 for modelling some large assemblies. I'm having 24gb RAM and NVIDIA quadro FX 3700 graphic card. However, My creo is very slow ( Even if i change to drawing  window, its gonna take atleast 2 min). Please help me out from this.
what is "large". Free RAM left?
Which CPU?
Creo needs a high single Core performance. A quadcore with 200Mhz more is better than a octacore with 200Mhz less per Core. Get some i7.
GPU is only the bottleneck if you rotate a view and it lags. But the FX3700 is quite old. you can get better (quadro) cards cheap.
here are some benchmarks Creo benchmark:
http://www.proesite.com/
br Bernhard
