I know you used to be able to do this in previous Pro/ENGINEER versions...when you colored a surface it would ask you if you wanted to color one side, the other side or both sides. Can you still do this in Creo Parametric 2.0? I can't seem to make it work! I have a previous model that has a quilt that is colored green on one side and red on the other. I can't re-create this in Creo Parametric 2.0. I know that I can make 2 surfaces with a very slight offset and make it work, but I should be able to make this work?
With some extra help I did find this:
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS31449&lang=en
And I verified that it worked. The <Alt>+<select> took a little bit to figure out. <Alt>+<select> then when the arrow comes up, release the <Alt> key and you may click on the arrow to alternate sides.
