Draft Analysis
Highlighted
Newbie
Draft Analysis
Hi Friends,
When I do Draft analysis for a part using Pro/E WF2.0 it only select the
single surface than the whole part could any one explain how to solve
it.
Ajit
Legal Disclaimer:
The information contained in this message may be privileged and confidential. It is intended to be read only by the individual or entity to whom it is addressed or by their designee. If the reader of this message is not the intended recipient, you are on notice that any distribution of this message, in any form, is strictly prohibited. If you have received this message in error, please immediately notify the sender and delete or destroy any copy of this message
7 REPLIES 7
Highlighted
RE: Draft Analysis
That's a good one. I couldn't figure it out either. If anyone knows how to
do a draft analysis on the entire part using WF2 please include me in your
response...
Highlighted
RE: Draft Analysis
When you are selecting your geometry - do a query select instead of
picking a surface and you will get a "solid geom" option.
Kevin Anderson <kevina@cornelius.com>
Sent by: -
11/06/2006 08:21 AM
Please respond to
To
"PTC/USER Model Discussion" <->
cc
Subject
Highlighted
RE: Draft Analysis
If you use the model tree you can select the part at the top of the tree.
Jim Ferdinand
WK Hillquist Inc.
603-595-7790 ex15
Highlighted
RE: Draft Analysis
Using the selection filter, select the solid geometry..
James
Highlighted
RE: Draft Analysis
I replied directly, but here it goes for everyone.
Select the part name at the top of the model tree. Then select
analysis, geometry, draft.
The only drawback is that the entire part stays selected when you draft
check it, so if it's a detailed part, it will spin slower. A bit
annoying, anyone got a fix for that? Anything I've done has un-done the
draft check.
Jim
Highlighted
RE: Draft Analysis
Select the model (very first item) from the model tree.
Cheers
Doug
Highlighted
RE: Draft Analysis
When you are selecting the surface to check, use the right mouse button and
click it three times slowly... On the third click, you will see all of the
solid surfaces highlight. I am sure there are other ways to select all
solids, this is just the one that I was taught and it seems to work all the
time.
HIH--
-Nathan
