Extruding a curved face - Creo Parametric (Schools Edition)
SOLVED
Highlighted
Hao
Newbie
Hi!, I'm really new to creo and i've been trying to model some basic real world items.
Currently, I've been trying to find a way to extrude a curved surface ON a curved surface (i.e http://1.bp.blogspot.com/_S57BC5oDY9s/SFyHztKA20I/AAAAAAAAAGc/2mIv53O6iI8/s1600/Joint+Push+Pull+03.j...) (I know it isn't creo, but it illustrates what I want). Basically,
i'm trying to make extrudes off a curved surface(a drink can for example) AND i want these new extrudes to have the same curvature as the drink can.
thanks so much if anyone can help!
Tags (3)
1 ACCEPTED SOLUTION
Re: Extruding a curved face - Creo Parametric (Schools Edition)
What you want is Edit>Offset.
Select the surface that you want your extrusion to originate from and go to Edit>Offset. On the dashboard you'll see four types of offsets, choose Expand Feature. Next, click Options>Sketched Region>Define. Pick a plane & reference surface for sketching--many different orientations for a plane will work so you'll have to decide which is best for your purpose--finish the sketch and set the height/depth of your offset.
1 REPLY 1
