FILL A HOLE ON A COMPLEX SURFACE
ronbak
I am trying to fill a hole on a complex surface.  I use curves to chop it up and boundary blends to fill it in.  However the tangencies are not perfect and I can still see a small seam.  Any suggestions would help.
1 ACCEPTED SOLUTION
psobejko
(To:ronbak)
Well, that's just a starting point.  At least it fills in part of your hole.  After you trim away at this copy and re-merge the the original quilt, you get kinda close:
11 REPLIES 11
psobejko
(To:ronbak)
Did you try selecting the quilt, and doing a copy and paste with the "untrim" boundary option?
This thread discusses similar "reverse-engineering" effort:
Is there a way to fill the hole?
ronbak
(To:psobejko)
I tried that and it doesn't give me the results I need. I lose the profile and I get overlap with the existing surfaces.
psobejko
(To:ronbak)
ronbak
(To:psobejko)
I like this approach.  It's almost there.  I will try it on the full surface.  i will post my results.
psobejko
(To:ronbak)
Cool, just keep in mind there are many ways of "skinning" the cat
Which makes me wonder - the quilt in your first post comes from an external copy geom reference - have you tried to obtain this original geometry?
ronbak
(To:psobejko)
yes but unfortunately they would not turn over the native file.  So I had to fill in some holes and use the warp feature to tweak things.
ronbak
(To:psobejko)
that's also why I like a second set of eyes looking at things.
ronbak
(To:psobejko)
here's my end surface. it looks pretty good.  thanks for all your help!!!
ronbak
(To:ronbak)
Here is how is stitched it together
This might be due to issues with the source model. I'm seeing some wonky intersections on the copy geom:
Yeah, after trimming out the center section, I was able to patch it pretty easily (pardon the quick and dirty modeling).
