Fill Surface
Gravel
Fill Surface
All,
I am trying to visit the contours and edges of a surface. This surface
was created by using Edit->Fill. I am finding that when I visit the
features in the model (ProSolidFeatVisit), then visit the surfaces of
the feature (ProFeatureGeomitemVisit), and then try to visit the
contours (ProSurfaceContourVisit) that it returns PRO_TK_E_NOT_FOUND.
Is there something different about this surface type (Fill) that it
doesn't have contours?
Patrick Williams
Application Engineer
Steelcase Inc.
RE: Fill Surface
The model that the surface is in contains no solid geometry. All it has
are datums and several fill surfaces. Is this why the surface contains
no contours?
Patrick Williams
Steelcase Inc.
RE: Fill Surface
All,
I was not filtering out the inactive (ProGeomitemIsInactive) geomitems
when visiting. So now I'm at the correct geomitem to visit the
contours. Thanks for all the help.
Patrick Williams
Steelcase Inc.
