Flatten round bottom bag
ErikClacey
I need to design a cylindrical bag with a hemispherical bottom. The diameter of the bag is 400mm and the bottom has a 180 hole in its centre. Having contacted the company making it, they want a flat model that they can use as a stencil and cut out the fabric. How do I make this happen? I was thinking that the Sheet metal module would be good but I can't seem to make it work. Also done it in the standard mode as a flat part with half "orange peel" shapes on the bottom but how can I fold it together, with the bottom so all connect properly.
10 REPLIES 10
http://en.wikipedia.org/wiki/Developable_surface
http://en.wikipedia.org/wiki/Euclidean_metric
Please use approximation - since you live in Euclidean metric space.
Hello, Erik.
I have managed to make a flat pattern of a hemispherical bottom by using a flange tool.
I just made a small round flat wall and then added a flange to it with a demanded radius.
In your case it should be 200 mm.
If you want to add some holes on this bottom you should use a filled pattern or just add them on the unbended part and then bend it again.
I hope it would help you.
Best Regards, Vladimir.
P.S.: It looks as if I've just discovered the fourth dimension thanks to Creo Parametric
Thank you for the assistance.
Ok Vladimir,
now please show me how do you do this with some real object like piece of paper without ripping or dents. Create a footboll using two A4 papers and post a picture.
It has been possible for a quite some time to use either flange tool, die/punch or flatten quilt&bend solid to create shapes that are not develovable - and still get a "flat state" of object. This flat state does not take in account any deformation nor plasticity - and therefore results are out of this world.
A simple proof - the circumference lenght of your flat state result will be larger than circumference of ball. Where do you put the extra material without any dents?
When it comes to textiles - you may strecth & compress fabric a bit and get somekind approximation of sphere using pieces. Think about footboll as an case.
http://en.wikipedia.org/wiki/Truncated_icosahedron
http://www.youtube.com/watch?v=5HNJB0vMq6w
So, using flatten quilt feature would get you closer to your goal:
Hello, Mikko.
And what about these?
Easy - using plastic deformation and ductile material you can form a spere from plate - but if fellow here wants to have solution with no plastic defomation (he was using fabric)....
Oh, yeah, Mikko! Of course you're absolutely right!
I should have studied better at my English classes
Now I understand that fabric is cloth produced by weaving or knitting textile fibres.
Sorry for misunderstanding.
Kind Regards, Vladimir.
No worries mate,
at least we managed to have a proper discussion about modelling possibilities with various cases.
Yours, Mikko
Hi. Yes the fabric that I'll be using is nonstretch. What I ended up doing, which is probably considered the "ugly" way is that I made the bag in 3d, then cut it into 10 slices. I then measured the lengh of each side, the surface measured height and then made a new part with these dimensions. Ugly but it worked.
The hot air balloon guys come to mind. In Creo, you can cut up the sphere and flatten the quilt of one of the segments. Since there will always be some level of deformation due to the nature of turning something linear into something spherical, you have to decide how many segments you want the supplier to join. The finer the "mesh" or segmenting, the closer you will come to a true sphere. I don't think Creo will tell you how much "fudging" it does to flatten a quilt. A manual grid mapping exercise may yield better results... or at least do both and compare for a sanity check.
Funny, however that the manufacturer cannot do this on their own. Are we beginning to rely on CAD too much? Are the true artisans of the world all retired now? ...flying hot air balloons
http://thewondrous.com/wp-content/uploads/2009/08/0061-600x400.jpg
