Freestyle in Creo Parametric
Newbie
Paul Sagar, Director of Product Management for Creo at PTC, demonstrates  the key capabilities of FreeStyle. Freestyle is a set of capabilities  inside Creo Parametric that allows for rapid freeform surface creation,  built on the concept of sub-divisional modeling. Create great looking  concepts rapidly from scratch, or leverage sketches from Creo Sketch to  turn 2D artwork into 3D models.
Re: Freestyle in Creo Parametric
Is it possible to import an existing mesh from another application and have it smoothed out by Creo?
David
This is currently not possible. Freestyle can only manipulate the mesh it creates.
Paul
This is brilliant to watch but impossible to follow if one wishes to emulate it.  You are obviously an expert on Freestyle, could you do a tutorial at normal speed for us mere mortals so we can pass it on to our charges? I have a lot of requests foir help with Freestyle and cannot do so except to point them here.
John E Forth
Lead Trainer Scotland. PTC Schools Program
John,
I checked the LearningExchange for tutorials on Freestyle and came up empty. You can suggest a tutorial to be created by contacting the site administrator.
-Dan
This video can be viewed on channel "ptcstudio" (http://www.youtube.com/user/ptcstudio#p/u) on youtube site, here (maximum resolution - 720p): http://www.youtube.com/watch?v=XHOnhB3bPjI
P.S. If necessary, this video can be downloaded using the following resource: http://www.keepvid.com/
