How to merge surfaces together to allow correct placement of a decal in Creo 2 Para
SOLVED
Newbie
I have just been sent a simple geometry that as been made with Freestyle in Creo 2 Parametric.
I would like to know if it is possible to merge the individual quilt surfaces together, so that a single decal can be applied to the entire model. This is the decal I would like to apply;
At the moment, I solidifiy the Freesytle, but as I can not merge the surfaces together, I end up with this
As you can see, the decal is only applied to one of the quilt surfaces, and I require it to be displayed on the entire model.
This is my first post on here, so I hope that this is sufficient information, however please accept my apologies if it is not.
Kind regards,
Ben
1 ACCEPTED SOLUTION
Re: How to merge surfaces together to allow correct placement of a decal in Creo 2 Para
Hello everyone,
I have had a play and I believe I may have solved it, with advice from Doug Schaefer.
If you apply the decal using 'Planar' mapping type, seems to apply the decal to the selected surfaces.
Thank you to everyone for the help!
Many thanks,
Ben
5 REPLIES 5
Hi Ben,
welcome to the forum. I am not sure how you are applying this decal to the surface, but are you picking multiple surfaces by holding down the control key as you select you surfaces? Or, right clicking over the surfaces, to query select through to intent surfaces?
John
Highlighted
John,
Thanks for your reply.
I am aware of the technique you describe, however I beleive this does not help, I can multi select the surfaces to apply the decal to,...
but as they are separate surfaces, this is the result;
As you can see, this is not what I am after. I require one, single decal, on the entire model.
Many thanks for your help.
Ben
Have you tried copying the required surface set, & applying the decal to that?
John
I thought there was a setting in the decal dialog to apply the decal across the surfaces. I'm not super familiar with this and I'm definitely not up to speed with the Creo2 color dialog, but take a look around.
Alternately, John's suggestion to copy the individual surfaces and applying the decal to the quilt might work.
LinkedIn
Hello everyone,
Many thanks,
Ben
