How to perform a simple swarf milling
SOLVED
Highlighted
Participant
I have little experience with multiaxis machining and I am struggling with a simple swarf milling. The surface i want to mill is the following:
I have tried several sequences. With swarf milling sequence the tool does not seem to follow the surface:
I can´t make trajectory sequence work...
I have done in the past some nice toolpaths with cut line milling but in this case i can´t get gouge free paths...
Any help would be greatly appreciated..
Some cross sections of the part:
1 ACCEPTED SOLUTION
Re: How to perform a simple swarf milling
Are you sure the surface can be machined with the tool side?
There are some concave looking areas - is there always a straight or convex path through each point on the surface, so that it can be machined?
5 REPLIES 5
Hi, you wish to machine this surface only with the side of the tool?
Yes, only the side
I think so. PTC is looking into it and the case has been reported to R&D...
It can´t be machined the way i wanted.... it is not geometrically possible.
