I think... I lost a file. Still in same session, dont know how to re-open.
SOLVED
I was working on a design this morning and had nearly completed it. At some point, I got side tracked with another project and accidentally closed that file in Creo 2.0. After looking at the Object List, I can see that it is still in the session, however I have no idea how to re-open it (facepalm).
Any suggestions would be greatly appreciated.
Tags (2)
Re: I think... I lost a file. Still in same session, dont know how to re-open.
Just click the "in session" button in the file open dialog and click on the "file name" you are trying to re-open.
By default, if a part or assembly is in session, it will read this before Creo/WF/Pro/E will read the disk.
Not sure about Creo as I'm still on Wildfire 5 but in the open dialog box it should have an "in session" option to the left.
