JPG into Creo Elements Pro / Wildfire 5
Highlighted
Newbie
ProE Users,
Can someone share how to put a JPG into a sketch in Creo Elements Pro / Wildfire 5. I believe you have to use the ISDX style feature but haven't done this since Proe 2001. Can't find the option, can anyone help?
Thank you
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
www.prioritydesigns.com
2 REPLIES 2
Highlighted
Users,
We figured it out. Highlight desired plane then Insert > Style Feature > Trace Sketch
Thank you
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
For those without ISDX, you can create a fill (flat surface) and apply a
decal to it. You need to manually scale it and adjust the aspect ratio, but
create some datum curves at the extents of the object to match the image
size and apply some transparency to the decal and you can sketch over
artwork nicely.
-Nate
