Machining equally spaced lines
Newbie
We need to create a texture with straight lines over a wavy surface, we
would like to have straight lines projected over the surface, and
machine them.
Which way would you do it? I mean as best practice...
We are doing it by projecting curves and using trajectory milling to
follow them,
however as there are a lot of them, is quite hogging, is there a better
way?
We have thought of some kind of surface milling with parallel lines, but
i don't know how to assure that the lines will be always on the same
position.
Thanks in advance,
Best regards,
Juan Vizoso
