When I do a pin connection the system always measures angles in an counter clockwise direction.
Similarly, when I do a slider connection the positive direction seems always to be left to right.
Is this possible to modify?
Bertil,
After selecting your constraints, you can flip them. This should change your direction. I no longer have WF3, but I tried it in WF5 and it worked there.
Hope this helps,
Tim
