Plane on a curve surface
bcat
8-Gravel
helo
i want to make a plan tangent to item at atached file
how i do this?
tank you
1 ACCEPTED SOLUTION
And as with all things Creo, another method is to have a divided arc on the sweep sketch. Run the sweep on the outside of the sweep profile. In this case, the plane is at the vertex of the sketch arc.
6 REPLIES 6
Constantin
(To:bcat)
This should be possible with a parallel plane (to one of the base datums) which has tangent as the second condition.
it is made: 2 points from both end, real value > axis >plane
That's more fun, Jack I wasn't thinking dynamic...
Thank you for find more fun than hate in PreE world!!! I do learn a lot from this community and make work more easy. It is real fun I do create some unique products by ProE and then 3 D printing.
TomD.inPDX
(To:bcat)
You will need to make some additional geometry to create that plane.
This example shows a geometry point offset from the sweep profile. You can use relations to manage the dimensions between the sweep profile sketch and the feature section.
