Problem with Tool Design Option
SOLVED
Highlighted
Participant
Is it possible to generate Core & Cavity(Volume Split) for this component in Creo Parametric using Tool Design Option?
I've tried me level best, but was not able to creat the parting surface for this component.
1 ACCEPTED SOLUTION
Re: Problem with Tool Design Option
Ok here you go.
It looks kinda messy in 4 of the corners but not too bad for starters.
Click on the image to make it larger.
4 REPLIES 4
Highlighted
hi Shashank,
I'm evaluating Creo TDO on Creo Parametric 2.0 this month. I've failed to make automatic parting surfaces for this and several other parts today.
I'll try to play with this one again later. Didn't have a chance to spend enough time on it yet.
Ok here you go.
Highlighted
Hi Jakub,
Awsome job..
i'll be very thankful if you could please upload the core cavity assembly as well...
Shashank
Highlighted
hi,
It's not gonna upload. Guess it's too big.
Check your pm.
~Jakub
