Radial Bolt pattern
MartinBrown
3-Visitor
Radial Bolt pattern
Greetings all! Happy Thanksgiving
I have an odd situation happening that I hope someone might have a suggestion.
I have a part detailed on a drawing, and a radial axis pattern has been added after the drawing was created so I don't want to start all over again...
This drawing will not show the bolt circle axis of this new axis pattern, I have a radial hole pattern on the same part and the same view that shows the bolt circle pattern just fine. But the axis pattern will not show properly.
As a test, I created a new drawing of the part and both the bolt circles show just fine.
I copied the *.dtl file from the new drawing that works properly and applied it to the drawing that isn't working. No luck.
radial_pattern_axis_circle is set to YES
This is working because I have a bolt circle showing on the same part in the same view...
Does anyone have a clue what I can do to slap Pro/E in the head and make it show the Bolt Circle in this drawing? Remember, I don't want to start all over again.
Thanks!!!
Martin T. Brown
Design Specialist
Facilities, Science & Technology
Merrick & Company
1099 Commerce Park Drive
Oak Ridge, Tennessee 37830
Direct: 865-241-4642
www.merrick.com
0 REPLIES 0
