Is there a setting or method to eliminate the model highlight (thereflection off themodel surfaces) in the results display? In the model, you can go into RENDER and edit the color to turn the highlightdown to 0, but it doesn't seem to have any effect in the results. Unfortunately, I did not turn the highlight down to 0 BEFORE running the analysis, so am I stuck with the highlight of the model AT the time the results were created? Certainly would be nice to be able to get rid of this. As it stands now, with the model results I am post-processing now, ANY straight on view of a surface gets wiped out by the highlighting.
