Spherical Patterns
ptc-2218360
Spherical Patterns
Gurus,
What is the best way to create a equi space spherical pattern that is easily
adjustable with quantity and spacing? I would like to pattern either a CSYS
or points.
WF 4.0 M130
Steve Miller
Mechanical Design
Impulse Devices, Inc
(530)273-6500 Ext. 128
(530)273-6566 FAX
Like a geodesic dome?
Try this:
Hi Steve,
The only regular equispace spherical patterns are those corresponding to the faces or vertices of the five regular polyhedra: Tetrahedron, Cube, Octahedron, Dodecahedron, and Icosahedron. As such the only possibilities for equispace patterns are those with 4, 6, 8, 12, and 20 instances.
If you examine objects like golf balls you'll see that they aren't exactly equispace.
Mike Foster
ATK
