Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Many thanks to those of you who wrote to help. It worked, as someone remembered the trick of using an alias in your syscols.scl file. Turns out, what I thought was an intact file was instead a newly generated file and it no longer had the entry to alias the axes to letter color.
