Summary - ISDX parameters.
Highlighted
Newbie
Hi All.
Apologies for the late response, it's been one of those weeks!
My thanks to Eric, Jb and Tim who were all very forthcoming with an
explanation! It's great to get a response from PTC and know that they
monitor these forums
Responces below..
Thanks again!
James
Jim,
I don't know exactly how the angle will show up, but if you "modify" the
Style feature it should show you where it is measuring the angle. That is
what clicking that little check mark does. I think that how that angle is
measured really depends on how you set up the curve.
Eric
Hi James,
It is the angle with respect to the Horizontal Axis of the Datum Plane
(DTM4) in your case. (since you are using a planar curve)
In case of Free curves, the elevation is active. In such a case it denotes
the elevation angle of the curve tangent with respect to the reference Datum
Plane.
Best Regards,
Jb..
The 2 angle parameters are measured relative to the reference plane in the
dialog. 'Angle' is measured in the plane relative to the Horiz direction
(note the H/V marker on the plane). The 'elevation' is measured from the
plane, assuming the tangent handle is not parallel to the plane.
To select a new reference plane, click in the Plane collector and select
your new plane reference.
Hope this helps
Regards
Tim
And again from Tim...
James,
As for the 2nd part of your question, does the attached help?
The 2 straight curves are my construction geom, and from these I build an
internal datum plane (all inside Style). Now I can reference the end angles
of the curved curve to this new plane, and therefore make them equal. Is
this what you're after?
Cheers
Tim
I've uploaded his attached part to a shared folder for all who are
interested! Very nice tip! Works great! Just click on the link and then
select the free option and you will be given a download option!
http://dl40l3.rapidshare.com/files/3524223/138485904/reference-angle-4james.
prt.1
Original Question.
Hi Everybody,
When defining a curve in ISDX, is it possible to tell what the parameter
"Angle" is referencing and if so, is it possible to change it?
