Surf mill cut definition
Newbie
Can anyone suggest a method to create cl in a surface mill sequence similiar to the follow hardwalls option in volume mill [right image in below link] - this is a 3D surface not planar.
See image here:
http://www-staff.lboro.ac.uk/~cdspk/images/cl_mc.jpg
I currently use 'cut lines'[left image]which is ok unless you have a disproportionate area which will then waste lots of time because the affective stepover in that area reduces to near zero.
I don't want to handle the narrow area seperately.
Any suggestions?
Cheers, Sean
