I am using Creo 2.0, M090. When setting up a Cutline Milling Sequence and using the selection filter to select surfaces, the filter only lets me pick the first surface of a given type then it goes back to all. After reselecting, the filter stays where I want it until I am done. This does not happen in profile milling or surface milling.
Select Cutline Milling
Select References Tab
Select Surface Collector
Set Filter to Mill Surface Surface
Select a surface from the desired Mill Surface
Filter goes back to "All" at this point
Reset the Filter to Mill Surface Surface
Now any amount of surfaces from this Mill Surface can be selected without resetting the filter.
Small issue, but something I use daily. Does anyone know if this happens in a later release than M090?
Thanks.
