Surfacing Help, 5 Sided Surface and Continuity
SOLVED
Re: Surfacing Help, 5 Sided Surface and Continuity
Unfortunately i can't open. TRY-OUT edition file....
Here an example with a spline close to the edge.
That's kinda what I was thinking. Boundary blend with curvature works pretty well for that.
Thanks all. A great many helpful ideas.
Finally was able to get back to this. Deleted all the curves and surfaces I had tried before. Went in, create a style feature, curves and then surfaces and everything worked perfectly the first time through!
Hmm, wonder why it didn't the previous tries. Maybe referencing non style curves or something? Initial look at reflection curves look good, but not sure about curvature yet. File attached if interested.
Good luck!
