Is there a way to un-set a load-point config.pro setting from the home/start-in config.pro? I want to remove something that shouldn't be in the load-point config.pro. The specific option doesn't have a default value, so I can't brute-force a NULL/empty/nothing/unset value.
Specific problem: load-point config.pro specifies pen1_line_weight which *might* be affecting my plots. I can't edit it out of the load-point config.pro because our launcher overwrites it every time.
Using WF5
Andrew Kelly, P.E. Design Engineer Honeywell Sensing and Control 2080 Arlingate Lane Columbus, OH 43228 Office: 614-850-7818 Toll Free: 800-848-6564 Fax: 614-850-1111 andrew.kelly@honeywell.com<">mailto:andrew.kelly@honeywell.com>
