What can be used to check sheet metal for errors
DavidAnthonySch
Hi, I was wondering if their are any tools/modules that when working with sheet metal can it discovery a hole if it is to close to the bend of the radius and among other various best design practices for sheet metal.
If you go to Edit-->Setup-->SheetMetal-->Design Rules you can setup your own rules for sheet metal like hole to close to bend. Then when you look at the model info it will tell you what rules you have broken. Save it as a template for everyone to follow.
