Why do some of my features have blue outlines?
Newbie
Why do some of my extruded objects on my hole punch have blue outlines around them when viewing them? For example, I extruded text 'HOLE PUNCH' and it has a blue outline, even in the DRAWING file as well. How do I remove the outline? It even occurs in some of the rectangular features I've extruded...what does the blue outline around it mean? Clicking and doing everything I know hasn't solved the problem
Above is an example of when I view the object in 3D space, no matter where I click or what I do the blue outline remains. The HOLE text is a wrapped projection onto a curved surface.
2 REPLIES 2
Re: Why do some of my features have blue outlines?
can u send the file>
Highlighted
If the text for the word hole is in an external sketch that you use, the sketch is still showing. If so, hide the sketch and go into view tab in the model and save changes.
Thanks, Dale
