cutting of solid part with surface
SOLVED
Highlighted
Newbie
I have a solid part and I wants to cut that part in certain pieces.
For the cutting I have a surface.
How to cut that solid with surface
thanks
1 ACCEPTED SOLUTION
Highlighted
Re: cutting of solid part with surface
I know one method to cut is
Click on the solidify and select remove.
Is this the appropriate method to do.
4 REPLIES 4
Highlighted
Highlighted
That's the only way, really. You can use an extrude feature and cut up to the surface, but that only uses the surface as the termination for the cut rather than cutting away the entire shape of the surface.
LinkedIn
Highlighted
What If I want to do the same in assembly.
Means I want to cut the assemble with certain profile of surface
Highlighted
You should be able to extrude a solid cut up to a quilt or surface. If the cut is linear and normal to a possible sketch plane, then you can also use the surface/quilt edge as a projection feature in the solid cut sketch.
I guess it all depends on the application.
