default surface finish value
SOLVED
Level 1
Is it possible to change default value of new created surface finish sign in drawing?
Thanks in advance
T.
Tags (1)
1 ACCEPTED SOLUTION
Re: default surface finish value
Create a new symbol using your preferred value as a default.
I created a reasonably comprehensive SF symbol I use.
Comprehensive Surface Finish Symbol
Attached: Creo 2.0
6 REPLIES 6
Tomas,
Could you please explain this in detail? Are you referring the default value 32 for surface finish?
Yes exactly.
Attached: Creo 2.0
Mapkeys are your friend. Make one ("sf") that places the symbol (OOTB or custom) and automatically sets the value to whatever you want.
Hi Tom,
Thanks for your tip, I think it's the best option.
I just tried to mouse record that mapkey, but it doesn't take the value I had put in in the recording script....it keeps the original 32.00.
Could you post your mapkey script? I have Creo Parametric 3.0 M130.
Here you go.  This one changes the value to 16.
mapkey sf @MAPKEY_NAMESurface Finish;@MAPKEY_LABELSurface Finish;\
mapkey(continued) ~ Command `ProCmdDwgCreateSurfFin` ;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist` 1 `generic`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist` 1 `generic`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist` 1 `standard.sym`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist` 1 `standard.sym`;\
mapkey(continued) ~ Select `drawing_sym` `tab_main` 1 `lay_var_text`;\
mapkey(continued) ~ FocusIn `drawing_sym` `inp_gtolchar.0`;\
mapkey(continued) ~ Update `drawing_sym` `inp_gtolchar.0` `16`;\
mapkey(continued) ~ Select `drawing_sym` `tab_main` 1 `lay_general`;\
mapkey(continued) ~ Activate `drawing_sym` `OK_push`;
