hello ProE CAM users...
I´ve been assigned to work with a model that was generated with an abs accuracy of 0.037 mm, this value is coarse by many standards.
In spite of this accuracy I´ve been told to purse the project.
Please look at the attached images.
Are the round surfaces <u>really</u> going to show up in the mold divided into multiple straight segments given the low accuracy that was used to create the model??? Should I be concerned about this ?
thank you, regards
AL.
