effect of coarse accuracy on mold surface
Newbie
hello ProE CAM users...
I´ve been assigned to work with a model that was generated with an abs accuracy of 0.037 mm, this value is coarse by many standards.
In spite of this accuracy I´ve been told to purse the project.
Please look at the attached images.
Are the round surfaces <u>really</u> going to show up in the mold divided into multiple straight segments given the low accuracy that was used to create the model??? Should I be concerned about this ?
thank you, regards
AL.
1 REPLY 1
Highlighted
RE: effect of coarse accuracy on mold surface
Yes this will affect your finish, I have had to remodel and create new splits for customers because3 of accuracy issues. Many people do this on purpose when giving files to their customers knowing another shop will be working on it.
